rothenberger gas torches
18 Aug 2004
hi,i am thinking of buying a rothenberger gas torch,either quick or super fire2.which one would you reccomend or is there any other brand/model which is just as good. your opinions would be greatly appreciated,thanks a lot. :roll:
... but if those are the ones which don't cut the flame immediately when you let go of the trigger, to me they'd be useless. Depends on the use perhaps, but I find the Rothenberger badged ones (made by a US company) hot enough for plumbing. 35mm pipe is easy even with normal propane gas and a small burner. Mapp gas and the standard (bigger) burner is just about ok for small brazing jobs.
