    Dismiss Notice
running a cable under a caravan
Discussion in 'Electrics UK' started by Booyaka, 28 Sep 2006.
  1. Booyaka
    Booyaka
    30 Aug 2006
    178
    Thanks Received:
    Country:
    hello
    very soon i will be running a cable from an outside light on a post next to a static caravan (holidaypark holiday home)and it needs to get to the the CU on the other side, i have seen that T&E has been run previoulsy under the bottom of the caravan but i was wondering whether you have to run the specific flex (3183Y) that is disigned for out side if its only clipped direct or is twin and earth ok as its static?
    many thanks
  2. Sponsored Links
  3. didthathurt
    didthathurt
    19 Aug 2006
    311
    Thanks Received:
    Kent
    Country:
    How does it get from the post to the van?
  4. Booyaka
    Booyaka
    30 Aug 2006
    178
    Thanks Received:
    Country:
    it will be clipped direct to the timber under the static caravan
  5. didthathurt
    didthathurt
    19 Aug 2006
    311
    Thanks Received:
    Kent
    Country:
    Sorry, I didn't make the question clear. You say
    so how is the cable going to bridge the gap between the post and the caravan - is there a gap?
  6. Booyaka
    Booyaka
    30 Aug 2006
    178
    Thanks Received:
    Country:
    there is a small gap but i will be sorting that by fixing a bridge of timber there, the main question i need answered is the one below if you wouldnt mind helping me out as its much appreciated..............
  7. Sponsored Links
  8. didthathurt
    didthathurt
    19 Aug 2006
    311
    Thanks Received:
    Kent
    Country:
  9. Booyaka
    Booyaka
    30 Aug 2006
    178
    Thanks Received:
    Country:
  10. didthathurt
    didthathurt
    19 Aug 2006
    311
    Thanks Received:
    Kent
    Country:
    That seems to be intended for use in kitchens and utility rooms and I tend towards advising that no kit should be used for a purpose that is not within it's general spec.. This sort of flex might be a better choice if you can't get hi-tuf.
    http://www.tlc-direct.co.uk/Main_Index/Cable_Index/Flex_Rubber/index.html
    The spec for this indicates its suitability for outdoor use which the 3183Y doesn't. They are more expensive, but that's because cable/flex for outdoor use has to be manufactured to a higher spec than cable/flex for indoor use.
  11. Booyaka
    Booyaka
    30 Aug 2006
    178
    Thanks Received:
    Country:
    many thanks mate
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
