    Dismiss Notice
running lighting cable in plaster board ceiling unaccessible
Discussion in 'Electrics UK' started by covcjd, 11 Mar 2005.
  1. covcjd
    covcjd
    10 Mar 2005
    6
    Thanks Received:
    Country:
    please advise me on the best and legal way of running lighting cable for 6 downlights (replacing 2 lots of spots). The problem is getting around / through the joists, without wrecking my ceiling.
    Cheers
  2. Sponsored Links
  3. masona
    masona
    5 Jan 2003
    12,885
    Thanks Received:
    125
    Essex
    Country:
    Is lifting floorboards upstairs possible :?:
  4. covcjd
    covcjd
    10 Mar 2005
    6
    Thanks Received:
    Country:
    Yes my darling wife wanted the floor above (bathroom) tiled. 2 years later when she wants the kitchen replacing she mentioned she wants downlights in the ceiling that happens to be below the tiled bathroom floor.
    Bite my lip or what?
  5. nstreet
    nstreet
    22 Nov 2003
    1,761
    Thanks Received:
    2
    Country:
    False ceiling, if you have the headroom.
  6. covcjd
    covcjd
    10 Mar 2005
    6
    Thanks Received:
    Country:
    This may sound lazy but I don't really want to go to the trouble of puting a false ceiling in.
  7. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    Can you get access to the void from under the floor of an upstairs room or landing adjoining the bathroom? i.e. joists running the right direction, no walls in the way?
    If not - new ceiling.
    Seriously - rip out the old one, do the stuff with the wiring, put up new plasterboard and get a plasterer in for cash-in-hand. Won't cost much compared to the overall cost of a new kitchen, and it'll be easier and a great deal quicker than fiddling about trying to do it via little access holes etc.
  8. covcjd
    covcjd
    10 Mar 2005
    6
    Thanks Received:
    Country:
    unfortunately the joists run the wrong way.
    Thanks for help anyway, it's time to have another think :idea:
    Cheers
  9. lewy
    lewy
    15 Nov 2004
    35
    Thanks Received:
    Bristol
    Country:
    rip the ceiling down, see my pics, I've just done exactly what you want to do.
    Makes a mess though :eek:
    [​IMG]
    [​IMG]
    [​IMG]
  10. Sponsored Links
  11. covcjd
    covcjd
    10 Mar 2005
    6
    Thanks Received:
    Country:
    I think I'll put the roses and spots back up
    :LOL:
  12. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    The cable and flex connecting the cooker look to be in a dodgy position relative to the hob...
  13. lewy
    lewy
    15 Nov 2004
    35
    Thanks Received:
    Bristol
    Country:
    yes they were, it was only temporary whilst i had everything in bits (2 days) the cable you see was only for the ignition for the gas hob. see new pics below
    [​IMG]
    [​IMG]
  14. felix
    felix
    23 Jan 2005
    898
    Thanks Received:
    2
    Country:
    1) Choose a line across your ceiling where all the holes in the joists will go. From a structural point of view this is best done near their ends. From a decorative point of view pick a bit of ceiling you don't see every time you walk through the door. With a metal detector make sure there are no nails along the line. This will save you much gnashing of teeth later - and not just yours!
    2) Carefully remove a long thin strip of plasterboard a bit wider than your drill. Try not to break it between joists. I wouldn't use a jig saw for this because you might just slice through a cable. You can use a hole cutting saw over the joists but save the disks to put back later.
    3) Do the wiring.
    4) Replace the missing plasterboard strip with as much of the original as you managed to get out in one piece. Make up any shortfall with new stuff.
    5) Patch up any holes or narrow gaps with filler then paint it.
    Job done.
  15. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    What was the big thick one that ran along the top of the tiles then dived down behind the cooker?
    Also - your floor. Do you plan to cover it up again, or restore the old quarry tiles? If the latter, any plans on how and with what? I guess this post is straying into Flooring Forum territory, but my kitchen has also got old vinyl/lino on top of what could, potentially, be a nice tiled floor, and I was thinking about uncovering it....
  16. theshogun
    theshogun
    25 Feb 2005
    102
    Thanks Received:
    Country:
    If you don't mind the look affix some mini trunking to the ceiling along one edge of the kitchen. Mini trunking size MT 3 this should give enough room.
    In line with your lights and the right side of any joists drill a 20mm hole through the back of the trunking and ceiling, then you can feed a 1mm t&e cable with the end folded over into the ceiling void, with the lights isolated and removed make a suitable hole to insert a stiff wire with hook on the end to fish said cable.If this is a down light position the better for joining the cables together in a joint box or you could put back the ceiling rose minus the pendant.
    Cut out your down light positions avoiding joists and batterns, you could use a stud detector for this or use a thin braddle and tap on ceiling to detect ,this method takes practice.
    In line with your down light positions drill through trunking and ceiling
    you can then fish the other end of cable tape on any further downlight position cables and repeat process.
    When finished before affixing the lid to the mini trunking block the holes up using a suitable fire proof sealer
    By the way you should install smoke hoods above downlights for fire safety, normally bought with light at wholesaler,
  17. Scoby_Beasley
    Scoby_Beasley
    1 May 2003
    1,881
    Thanks Received:
    50
    Durham
    Country:
    But only when installing in insulation, not a void :?: :eek:
Loading...
Share This Page
