Apologies as this will be a bit of a numpty question... but.... Had a scare tonight when my daughter appeared from her bedroom holding a cheapo hairdrier that had been plugged into a bog-standard extension lead and had started sparking and scorched her bedding ! The cable had been crimped and perished by the look of it - and it must have cost all of £5.99 from Tesco ! Dread to think what might have happened if had happened in a different timeframe.
So anyway... moving on.. what should I get to replace the extension lead. At least it will be individually switched sockets with clear instruction to switch em all off apart from the eternal mobile phone connector of course. Is there anything else I should consider getting (apart from a smarter daughter) - are there RCD protected extensions that would offer more safety? Or RCD plugs for normal extensions ? Dont think surge protection helps in this regard ? All advice welcome.
