Satin Chrome Finish Plug-In Plate
they are mains trac fittings. I suspect although not my choice for a lighting source they are likely to be ok ish. Lamps supplied likely to be unbranded. Where are you putting them. I would say ok in bedrooms but not for me in a kitchen
as you are new, when you change the light apart from the obvious, please note my signature, you will be glad you did
plug in lights are only easy to install if you have a standard pendant light to plug it into. if you are going to replace an existing spot light, or halogen fitting etc. you will need to fit a ceiling rose/pendant before you fit these lights. load of rubbish really. get the real deal - its not difficult to wire up.
just bought them from Argos (have an excellent returns policy) and must admit they look better than i thought, took 2 mins to fit- two simple screws into the ceiling, and fit into usual light socket- haven't tried them fully yet, but time will tell!
