Saunier SD623 No HW
Discussion in 'Plumbing and Central Heating' started by paulwilliam, 17 Sep 2006.
  1. paulwilliam
    paulwilliam
    17 Sep 2006
    2
    Thanks Received:
    Birmingham
    Country:
    Read couple of forums and changed diaphragm as recommended (full of holes) Thanks people. Feel confident fitted correct??? However actuating switch still not pushing microswitches 2,3.when hot tap turned on. Can turn on HW by pressing microswitches manually. Heating ok Pressure ok. Any ideas..
  2. Sponsored Links
  3. croydoncorgi
    croydoncorgi
    6 Jun 2004
    4,021
    Thanks Received:
    340
    London
    Country:
    Is diaphragm pushrod moving at all?
  4. kevplumb
    kevplumb
    18 May 2004
    23,712
    Thanks Received:
    925
    depends where i get sent
    Country:
    scale might be playing a part :idea:
  5. Agile
    Agile
    26 Jun 2004
    64,039
    Thanks Received:
    4,595
    London
    Country:
    Replacing that part without any leaks on reasembly is quite a task and hardly worth it on such an old and problematic boiler.
    When replacing the diaphragm did you check that the spindle was moving freely ( and dry and grease it ) ?
    Tony
  6. galwag
    galwag
    4 Dec 2003
    73
    Thanks Received:
    3
    Country:
    water valve to this boiler has a built in differential valve
    from memory it is plastic with a small spring attached and goes into inlet side of valve
    if this is missing damaged or reassembled incorrectly then water valve will not activate microswitches
  7. paulwilliam
    paulwilliam
    17 Sep 2006
    2
    Thanks Received:
    Birmingham
    Country:
    Push rod slightly moving but little force behind it. Will check spring and my fixing again. Selling house soon don't want expense of new boiler with new regs.
    Cheers Peeps
  8. Agile
    Agile
    26 Jun 2004
    64,039
    Thanks Received:
    4,595
    London
    Country:
    A brand new boiler under the manufacturers guaranty is a distinct advantage when selling a house and I usually suggest the advantage is worth £3k to £5k whilst the cost is about £2k.
    I hope you dont remove the light bulbs when you sell a property!
    Tony
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
