Sealing a cut in exterior brickwork
9 Dec 2013
The lead which was covering our porch was stolen a few months ago and the removal of it has left a cut/groove above the porch where the lead was slotted into. I now want to seal this cut as it is letting in damp through the brickwork. My question is, what do I use for this?
Many thanks in advance.
Bastards
Is the porch still there? If it is you will still need a flashing detail. Please advise.
Yes , the little porch is still there -is a small flat wooden protrusion measuring around 2ft Square- and I thought I could protect it with some left over roofing felt from our garden shed (at least it that won't be nicked! ).
Hi Alistair. Thanks for your reply, but I'm afraid you've lost this inexperienced diy-er -what is Flashband and would that stop the damp getting in? Or is it more for covering the porch? Thanks for you help...
It will seal the join between the roof and wall, it comes in rolls 6" 9" etc looks like tar backed tinfoil...heat it with a heat gun or hairdryer and press it into place.
