    Dismiss Notice
Sealing around the bath
Discussion in 'Decorating and Painting' started by russellm72, 1 Dec 2005.
  1. russellm72
    russellm72
    21 Jul 2004
    43
    Thanks Received:
    Country:
    I currently have plastic coving round my bath to seal the edges from water. The problem is it's getting quite old now and I need to replace the material. I took a bit off the other day and found that underneath the bath has been sealed to the tiles with a big dollop of silicon sealant. I expect that the coving is just there for a nice finish?
    Can anyone tell me where I can get this coving from? I tried B@Q the other day but the guy looked clueless!
    I have seen you can buy such things from online stores but I'd rather get some this weekend and get it finished.
    Many Thanks
    Russell. :rolleyes:
  2. Sponsored Links
  3. waynes
    waynes
    10 Aug 2005
    82
    Thanks Received:
    Cambridgeshire
    Country:
    topps tiles is where i got mine from, a quick look online should show your closest store
  4. gcol
    gcol
    22 Sep 2005
    6,594
    Thanks Received:
    65
    Preston, Lancashire
    Country:
    Don't bother with that plastic trim - it looks bad.
    I suggest you remove the old sealant with a sharp chisel (very easy to do and should take about 15 mins). Clean and dry the area. Mask off a nice straight line (top and bottom of the joint) using either masking tape or electrical tape (electrical tape sticks to tile better than masking tape).
    Fill the bath with cold water.
    Apply a bead of sealant to the joint then run along the bead with your finger in one continuous movement.
    Remove the tape as soon as you've done this.
    You should now have a perfect seal around your bath that looks much neater and works better that that plastic trim.
    Drain the water from the bath after a couiple of hours when the sealant has gone off.
    Cheers,
    Gcol
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
