I would be grateful for some help on this topic. A few years ago I installed an electric shower, but recently I have read that the circuit should be protected with an RCD. At present, it is simply protected by a 40A MCB. I found a separate shower CU at Screwfix, but am dubious about how it actually fits into the circuit. Does a connection (separate from the main CU) need to be made from the incoming supply to the house, and if so, how easy is it? I presume that I can't simply insert it into the shower circuit, because how would it connect back to the main CU?
Thanks in advance.
Thanks in advance.
