Hi
I've just taken delivery of a DAR Alto shaverlight. Very odd connection method - there is an external choc block with an IP44 cover (size about 1" * 1" * 2" in all). It appears you are supposed to create a cavity in the wall/tiling for this - odd, but fair enough, however the choc bloc is on short leads and right next to one of the fixing screws - would be quite difficult to create a suitable cavity without ending up screwing into open air.
Secondly the unit is double instulated and has no earth connection. Yet it is a metal box with a chrome/glass facia (internal wires run around edge of the metal box). As we will be placing rechargable shavers and toothbrushes on to of the unit the risk of either the light itself or a charger/ lead making the metalwork live seems unacceptable.
I will be moving the choc block inside the unit and adding an earth under one of the mounting screws, for a more conventional installation.
From the design I suspected that this was a non-UK item, however I see from www.darlighting.co.uk that they are an english company with a UK factory. Is the original design really acceptable in the UK?
