    Dismiss Notice
Shelf hanging disaster
Discussion in 'DIY Disasters' started by garash, 30 Jul 2019.
  1. garash
    garash
    3 Sep 2014
    150
    Thanks Received:
    2
    Essex
    Country:
    Using standard white board and L shape brackets I have for the first time been unable to complete the job and in fact have likely created a problem. The wall is stud/false made of cement? ( the dust is grey but could be plaster?). It seems to be something like 1 to 2 inches thick. Immediately behind is a solid brick wall. I first tried traditional rawlplug and screws which were 1 3/4 inch long but they just fell out of the holes with the shelf attachedThen I tried Toggle bolts. I have drilled the holes slotted in the toggles, screwed the brackets up really tight but there was still movement. As well as not being able to tell if there is any space at all between both walls for the toggles to sit, I could not understand why they remained visible at the front edge of the hole? I thought they should go back to where the gap is so they can open up?. The size of these are M4 x 50mm with a fitting clearance of 9-20mm. Any suggestions how to remedy this taking into account the size of the wretched holes I now have!!! Thank you.
  2. Lower
    Lower
    22 Dec 2005
    996
    Thanks Received:
    88
    Leicestershire
    Country:
    Drill into the brick and use longer screws.
  3. garash
    garash
    3 Sep 2014
    150
    Thanks Received:
    2
    Essex
    Country:
    Yes I have thought of that although I would have to choose a different place as I don't think you can get rawlplugs half inch across lol
  4. Lower
    Lower
    22 Dec 2005
    996
    Thanks Received:
    88
    Leicestershire
    Country:
    Move the shelf brackets to an area of the wall where you haven't drilled oversized holes and then fill the holes you have drilled.
    Alternatively, use resin fixings if you need to use the holes you've created.
    • Thanks Thanks x 1
  5. jonbey
    jonbey
    17 May 2012
    2,744
    Thanks Received:
    131
    Country:
    If you have a long plug into the block wall then the big hole won't matter, will it? If not entirely hidden by the bracket you can add some filler.
    • Thanks Thanks x 1
  6. foxhole
    foxhole
    14 Mar 2006
    14,070
    Thanks Received:
    1,509
    Kent
    Country:
    You can only use toggle bolts with a cavity which you said you did not have?
  7. gasbanni
    gasbanni
    7 Jan 2007
    7,609
    Thanks Received:
    803
    Country:
    As already said use longer screws put your plugs on the end of the screws and hammer them in to the wall ....undo the screws do the same again with a fresh plug on your screws ......when you finally screw the tight they will hold ....superbly.
  8. daggermark
    daggermark
    11 Jul 2017
    74
    Thanks Received:
    6
    Country:
    Talking of which, reminds me of a 'handyman' that my mate recruited to add some shelves to his kitchen on a stud wall. He put them up with nylon plasterboard plugs and didn't mention anything about how much weight the shelf would hold... my mate was rudely awoken in the night by the sound of smashing jars and a floor covered in rice and pasta sauces.
  9. Chud
    Chud
    6 Dec 2006
    696
    Thanks Received:
    57
    Dorset
    Country:
    It wasn't Handy Andy was it?
    Still makes me ROFL seeing the faces when that happened on Changing Rooms...
    • Like Like x 1
Loading...
Share This Page
