Shower pipes
27 Oct 2009
Bristol
Hello all,
I am in the very final stages of my bathroom refurb.
I am connecting the mains fed shower valve and shower head this weekend but have one question:
At present I have drilled 2x 10mm holes for the shower pipes to protrude through the wall ready to connect the valve (one hot and one cold pipe).
I will need to put some form of filler or grout around the pipes to hold them firmly in this 10mm hole, bearing in mind that the shower valve is mounted and secured solely on the protruding pipes.
I was considering using tile adhesive around the pipes, letting it set overnight then mounting the valves, however I am concerned about any chemical reactions with the copper pipework.
Can anyone suggest a suitable filler material or any other clever ideas?
I'll post my bathroom project photos from start to finish in the case studies section when complete next week.
Thankyou!
10mm pipes :shock:
what shower is it make/model ?
no shower valve hangs on the pipes only and don't use 10mm supplies.
I think the OP means 15mm and I would recommend something like Plastic Padding if he's going to rely on the copper pipes to support the valve.
right but you useally need to fit the doglegs to connect the 15mm pipe to the 3/4" shower valve.
or use a concealed bracket etc.
Thanks seco. The concealed bracket would have been a good idea in hindsight but the tiling is complete now so I don't want to rip out the tiling.
What filler material would be best to hold the pipes securely? ...Rigidraider you mentioned plastic padding?
fit these then
how was you intending on fixing the pipes to the shower then ?
if you use these just run some silicone around the pipes.
then the brackets take the weight not the pipes
Brilliant thanks seco. Where can I get these from?
The shower comes with dome covers. I had simply fitted a 15mm to 3/4" adaptor on the end of the dog legs and was then going to just set the pipes in place with some kind of filler, then screw the dome covers on and fit the valve.
yep
if you have used the doglegs you shouldn't need an adaptor as they are 15mm x 3/4" already.
how have you connected the dogleg to the pipe.
by one of these
have you a pic ?
or drawing ?
