We have a shower that is fed from the mains water / hot water tank (i.e. not an electric shower with a heating element built in).
Yesterday, the pressure in the shower dropped to basically zero, in that only a small trickle of water now comes out of the showerhead. Previously, the shower had a strong, steady stream of water.
The water pressure is least when the dial for the mixer control (for the level of hot water vs. cold water) is turned fully to "hot". Although even when this is turned fully to "cold", the water pressure is still extremely weak.
Is there anything obvious that we can do to try and fix this in advance of calling a plumber?
I've attached pictures below of the shower head/fitting and hot water tank.
