Shower Pull Switch Problem (Melting)
28 Mar 2003
Hi.
My mum has a Mira electric shower and I replaced the pull switch about a year ago as it stopped working and there seemed to be some charring inside and the plastic had cracked. Now the new one has broken and when I look inside the live wire has melted its plastic and is black and charred for about an inch and a half and the plastic around the terminal is cracked and burnt.
What is causing this? The shower has a separate fuse box downstairs and seems to have been properly fitted.
Any suggestions?
Thanks.
18 Mar 2005
most probably loose connection i see this all the time. when tightening terminals use the largest screwdriver you can not one of those tiny ended glass terminal neon type drivers. screw it down tight as you can then no probs
8 Jul 2006
Yorkshire
its down to poor connections, therefore you get this arcing/piting and burning of the conductor and terminal.
you need to make sure the termination is really good and properly done( no loose strands missing)
also is it a good quality switch/pullcord?
this can make a difference.
is it highly rated enough for the shower? ( it should be)
18 Mar 2005
casper, after you have fitted the new pull cord dont screw it back together wait 5 mins and re-tighten you will probably find it will"nick up"a bit more as the cable beds in
31 Mar 2006
Leeds
Also when you remake the new switch, make sure you cut off all the damaged wiring. This will often extend past where the burning on the insulation stops. The copper will be discoloured from the heat, and this can cause a higher resstance joint, which may lead to another burnt out pull switch.
11 Jan 2004
Of course, you may run out of slack, in which case you need to replace the whole piece rather than rely on (another) cable joint!!
