Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Best option is to operate the pull switch only when the shower is switched off at the shower itself. This prevents arcing in the contacts of the pull switch and thus extending its life time. Arcing wears the contacts and worn contacts can become hot when passing current and that is the most common reason for failaure of shower pull switches.
Turning the pull switch off after the shower is turned off does remove power from the shower so it is marginally safer to do so.
the showers always turned off using the off button on the shower. but just wanted to know if the pull switch is safe to leave on all the time, someone told me to just leave it on but don't want the switch to burn out, if that would even happen.
