Hello everyone,
Hope all is well
I am renovating my bathroom and have done a lot research, although am still unsure as to what pump I require.
Firstly, let me explain what water system I am dealing with...
I have a gravity fed system, with the cold water tank being in the loft and feeding just the hot water cylinder, which means the rest of the cold water taps are fed through the mains. My hot water cylinder is located on the first floor, adjacent to the bathroom, I am refurbishing.
I would like to install a single pump to feed both basin and shower. Having spoken to pump wise they are suggesting I install an negative head shower pump, because I am pumping the hot water against the cold mains, however I do not understand why.
The question is can i get away with a positive head pump?
or will it cause complications?
and what pump would you recommend for my needs that will:
a) provide sufficient pressure.
b) be quiet.
Thank for reading
Hope all is well
b) be quiet.
Thank for reading
