shower pump cutting out
28 Jan 2014
i have a salamanda ct50 fitted in the loft of the house i moved into, the hot tank is in the bedroom and the cws is about 500mm above the pump. it was working ok but started to cut out. i thought it was the mixer so i have replaced it. the shower pump works ok if on full hot or full cold but when i adjust it to mix both hot and cold it cuts in and out. can any one shed any light on this.
thanks
