Hi Just wondering if anybody could help with this.
just about to put in a shower pump in for a customer and im not too sure how it should be wired, it said it should be on a pull cord isolation switch and spured off an existing ring, so i was wondering if it would be ok to wire it into the same ring as the light in the bathroom????
or could i spur off the immersion heater ring??
the manual says the following about the electrics, is what i thought (above right or am i just been stupid?) if so any sugestions? or is it a job for someone with Part P??
any suggestions appreciated.
ELECTRICAL INSTALLATION
THIS PUMP MUST BE EARTHED
The electrical installation MUST be undertaken by a competent person and MUST comply with the relevant IEE regulations.
All pipework must be cross bonded and an RCCB fitted in compliance with IEE regulations.
The 240 volt supply should be taken via a fused spur from the domestic ring main and fitted with a 5 amp fuse. Higher rated fuses should not be fitted.
