Shower pump
2 Apr 2009
Lancashire
I need to install a shower pump. Cylinder on the landing in cupboard, large cws tank in loft, where best to install essex flange/similar and where do i connect up hot and cold? thanks.
Pump on floor in airing cupboard; dedicated 22mm pump feeds from the CWS tank (opposite end to the incoming feed) & HW cylinder; an Essex flange fitted into the side of the tank at the top is best but, alternatively, a York, Surrey or Warix flange in the top/vent outlet. Pumped supply to shower can be 15mm but 22mm is best where high volume shower heads; use only full bore isolator valves to avoid restrictions.
For your shower to work properly, it’s very important that the design & layout of the H/C pipe work is correctly done, you buy the correct positive or negative head pump to suit the installation & you have adequate HW/CW storage – 250 litres cold, 150 litres hot but larger in a busy household or multiple shower installations.
This usefull guide will give you an idea of the do’s & don’ts; http://www.salamanderpumps.co.uk/Download/instructions.pdf
but all pumps follow similar guidelines.
am fitting a shower pump in airing cupboard, whats the minimum run of copper pipe that has to be between the surrey flange and the pump
thanks
thanks
Gripper, please come back with your own post, don’t hi-jack someone else’s :roll:
