I fitted a Salamander shower pump under my bath. I have hot and cold water pipes coming up through the floorboards which used to connect straight to my bath mixer tap.
I changed this so a pump sits in between the pipes coming through the floor boards and the mixer tap. Everything was fine until I decidd to move the pump to the other side of the bath (as the a new sink restrcts access to the pump).
Since putting this extra pipe work in I have noticed that the pump attempts to kick in everytime i turn on the bathroom sink tap or the Kitchen tap. It hums for a split second and then stops immediately.
I assume this is because the flow is disturbed and therefore the pump tries to kick in but then stops when it realises there is not an opening.
Is this an issue? Does it need sorting and how can i sort (raise height of pump?) and will it effect the life of my pump????
THANKS
THANKS
