    Dismiss Notice
Shower too hot!
Discussion in 'Plumbing and Central Heating' started by Mattboyslim, 9 Jun 2011.
  1. Mattboyslim
    Mattboyslim
    8 May 2011
    18
    Thanks Received:
    Bournemouth
    Country:
    Hi guys, was wondering if anyone could help. I have recently bought a bungalow which has a relatively new shower (manual mixer) and a combi boiler installed. It's a really nice powerful shower but on it's coldest setting it's still pretty hot and as the summer comes I am gonna be wanting a cold shower now and then!
    Could anyone advise me on how to fix the problem?
    Cheers, Matt
  2. Sponsored Links
  3. PlumbGas
    PlumbGas
    26 Feb 2011
    398
    Thanks Received:
    57
    Surrey
    Country:
    will need more info. make and model ? picture maybe
  4. Mattboyslim
    Mattboyslim
    8 May 2011
    18
    Thanks Received:
    Bournemouth
    Country:
    I'm not sure of the make and model - there are no manufacturers markings on it. It is like a stainless steel t-bar that comes out of the wall and has rotating ends. One end for turning it on and the other for the temperature control.
    If this is still no help then I'll take a pic when I get home from work and post it up. Thanks
    Edit: it looks just like the one at the top of this link:
    http://www.bellabathrooms.co.uk/triton-low-pressure-exposed-valve-thermostatic-mixer-shower.html
  5. PlumbGas
    PlumbGas
    26 Feb 2011
    398
    Thanks Received:
    57
    Surrey
    Country:
    Will need pic then as all manufacturers make showers like the one in the pic, but it sounds like the thermostatic cartridge may need replacing anyhow,
  6. Mattboyslim
    Mattboyslim
    8 May 2011
    18
    Thanks Received:
    Bournemouth
    Country:
    Ok mate, I'll post up a pic when I get home tonight
  7. Charnwood
    Charnwood
    29 Apr 2011
    3,579
    Thanks Received:
    512
    Country:
    The hot water is fed from the combi, but where is the cold coming from?
  8. picasso
    picasso
    8 Apr 2008
    10,639
    Thanks Received:
    2,672
    Essex
    Country:
    check that the hot is plumbed in on the left (as you look at the shower) seems to be a common installation error to get the hot and cold supplies the wrong way round.
  9. Mattboyslim
    Mattboyslim
    8 May 2011
    18
    Thanks Received:
    Bournemouth
    Country:
    charnwood - no idea where the cold is fed from mate but i know it's there because the temp does change hotter when you move the dial
    Picasso - yeah i think it's plumbed in right because when i move the dial hotter, the water gets super hot, just doesnt go very cold
    plumbgas - here's the pic mate, if its not what you want then i can take more :)
    http://www.diynot.com/network/Mattboyslim/albums/
  10. Sponsored Links
  11. carlsquires
    carlsquires
    20 Apr 2011
    44
    Thanks Received:
    2
    Country:
    Sometimes the dial on the temp control will only turn so far. Try turning it down with the dial head removed.
  12. Mattboyslim
    Mattboyslim
    8 May 2011
    18
    Thanks Received:
    Bournemouth
    Country:
    i played around with the shower last night and set it on it hottest setting (which was scalding!) then i turned the dial to its coldest and it did go cold for a few seconds before it got hot again...
    I'm thinking that this means it is something to do with the thermostat so does anyone know how to change the thermostat on one of these shower types?
    Here's the shower pic link again http://www.diynot.com/network/Mattboyslim/albums/
  13. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    Chances are that you don't have a manual mixer but a thermostatic one with a knackered cartridge.
    Another option is a cowboy boiler install where they left the bathroom cold supply from the tank.
  14. Mattboyslim
    Mattboyslim
    8 May 2011
    18
    Thanks Received:
    Bournemouth
    Country:
    damn i hope not - is there any way i can find out whether it is the thermostatic cartridge that's causing the problem?
  15. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    With the boiler dhw thermostat on max, how much does the shower temp change when you turn the control from one end to the other?
    If you turn the stopcock for the whole house off, what happens when you open the shower?
  16. JonB
    JonB
    9 Apr 2005
    590
    Thanks Received:
    24
    Cleveland
    Country:
    Im no shower expert, but is your combi not turned up to high if its scalding.
    JonB
  17. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    No. Mixer should be able to adjust whatever hot and cold supply.
Loading...
Share This Page
