Hi
I'm confused (doesn't take much).
Got a new shower room in my loft conversion and the tray fills up. It doesn't over flow because once it gets to a certain depth the weight of the water seems to increase the flow down the waste.
If I do a short sharp plunge on the waste, the flow suddenly increases, the water drains away and all is fine for the rest of the shower.
Then, gradually, over a day, the problem comes back.
So, this can't be the size of the pipe as after a plunge it's fine, so the capacity must be there.
Any idea what the issue could be?
My ideas are:
1. air lock
2. there is some kind of sludge in the pipe - when I plunge it's dispersed allowing better flow but over time settles back to the lowest point and restricts the pip.
These are probably both a load of rubbish but that's where I thought you guys may be able to help!
Thanks a lot in advance
My ideas are:
1. air lock
