Hello...
When i bought my house 8 months ago i ripped out the original bathroom and fitted a new bath with a power shower (2 bar pumped) which i must say is awesome! However...ive always had issues with my drainage.
Basically i replaced all the old waste pipes but did not alter the route or angle, and now am unsure whether i simply have too much flow for the drain to cope with, or whether i can adjust angles / add a vent etc to improve things.
Right...the drain is a standard bath 50mm plug which is connected to a 40mm trap. Then (and proetty much horizontally) a waste piupe is connected from the trap, goes through the wall outside and is connected to a 40mm 90 deg elbow. There is then a pipe with a shallow drop going into the drain. Overall id estimate the length is about 2 metres. I also get a lot of slurping / garging noise coming from the bath overflow when i either drain the bath or have the shower on fairly powerful.
My shower pump states it can deliver 25 ltrs per minute. The feed to the shower is via 2 x 22mm tubes to a mixer. The flowrate is incredibly good, but usually i end up standing in a pool of water when i have a shower! This is with the shower on about 30% power.
Oh yeah...also ive checked and cleaned ALL my waste pipe out last week. Also this has been a bit of an issue ive been living with since i put the bath in.
Any help would be great.
