I have a 10.5kw shower that was fitted over two yrs ago. Recently the pull switch stopped working so i replaced it. When i removed the old one it looked melted and black as if fire had started. The wiring is 10mm coming from CU 40amp RCD. in to a 45Amp pull switch. When the shower is run the wiring really heats up. Just looking for advice regarding this as the shower was fitted by a qualified electrician apparently.
I have also ran the shower then isolated and opened it. the wiring inside was really warm.
I am going to get qualified spark tae look at it but would like advise so i don't get ripped off.
Regards Alan
Regards Alan
