i am going to install a 9.5kw electric shower i have a 7.5kw at present running on 6mm cable on a 32amp mcb the distance between fuse box and isolator switch is around 8ft running up side of wall via trunking in to loft to iso/switch would 6mm cope with 9.5kw or would it be best to change cable to 10mm on a 40amp mcb thanks
