My boiler will try and fire up the fan starts then the burner ignites then the lot goes off.red light comes on. if you switch the mains off and on a few times it clears the fault. Some times it will start its self and run for a few minutes. If you try and get hot water the lot shuts down. One engineer said it was the pcb board with out opening the case. any thoughts
