Hi there,
I have a Sime Friendly Format 80E boiler (or possibly a Friendly Format Technyl judging by part numbers) which is <5 years old, and have a classic problem...
The CH works absolutely fine, but we're experiencing problems with the DHW only being lukewarm AND low pressure - typical symptoms of a faulty Diverter Valve. However the plot thickens...
When turning a DHW tap on, the boiler fires up correctly and watching the Diverter Valve in operation shows that the diapragm is still working, as the pin extends and depresses the microswitch (not sure what this microswitch does). So I'm not 100% convinced its the Diverter Valve (possibly the Heat Exchanger?).
Despite the Diapragm looking like it works in terms of depressing the microswitch, the DHW only warms a little, and the CH flow pipe gets a lot hotter - as do the radiators. So, from my limited knowledge, I think its either the "valve" part (not the microswitch triggerring part) of the Diverter valve not fully diverting water to the DHW Heat Exchanger, or its the DHW Heat Exchanger itself.
Now, upon examining the DHW Heat Exchanger by touching the back, the left half gets warm and sometimes very hot, but the right half is always very cold, so I'm wondering if this is indicative of a clogged up or faulty DHW Heat Exchanger?
What I need to establish is which of the two parts (hopefully not both) is actually at fault here - is it the Diverter Valve or the DHW Heat Exchanger that I need to replace?
Had the system recently serviced, and the plumber said striaght away that I need to replace the Diverter Valve as the radiators heat up when the hot taps are open, but he also said he's not that familiar with the Sime boilers (lucky him), so what should I do?
Any advice would be VERY handy, and my intention is to replace the part myself, and then get the boiler and system re-serviced to get those nice warm showers in the morning again!
Thanks in advance for your help.
Sangers.
Sangers.
