Single skin brick porch condensation
2 Jan 2019
We have a porch that has a single skin dwarf wall. It's then just double glazed pvc right up to the roof. It's basically an extension of the bay window to the corner of the house.
I know single skin brick is prone to condensation but when we get a lot of rain which we have had recently its much worse and starts to develop mildew. I don't think it's penetrating damp. I could be wrong but is it because the brick is sucking moisture from the rain and therefore more prone to condensation. We do open the window to provide ventilation but when it's cold at night we shut it.
I guess the question is would it be benefiticial to paint the outside with stormdry or some kind of water repellent. Would it help? The porch is painted inside with dulux weathershield to make it look nice.
I've read that bricks need to be able to breathe. I think weathershield is breathable?
Some kind of vents might help with air circulation, like trickle vents above the windows or similar. Might need various ones in different places to allow air to circulate between them
Yes coat the wall with a water repellant and see how you get on before messing about with ventilation. The pointing must be in good condition. If you use a silicone product, bear in mind its not normally UV stable and needs re-doing every 3-5 years.
I was thinking stormdry? It's like a cream that dries clear isn't it? Will it be OK the brick being painted on the inside as the brick needs be able to breathe doesn't it?
Masonry water repellents are not like paint or varnish and do not actually seal the surface, the wall remains breathable.
