masona said:2/3 plus the thickness of the skirting board
ie: skirting board 15mm thickness = minimum 45mm nail
Say you want to fit a 1" batten onto the wall then you will need a minimum of 3" nail.Eddie M said:masona said:2/3 plus the thickness of the skirting board
Do you mean 2/3 of the thickness of the skirting board, plus the thickness of the skirting board, as this would be 15mm + 2/3 x 15mm = 25mm ?
masona said:Screw & rawlplug is the best way.
or make your own pellets with a special tool from the back of the skirting boardkeyplayer said:masona said:Screw & rawlplug is the best way.
How do you best lose your screw heads if you're waxing rather than painting?
