Slight leak on mdpe fitting
16 Jul 2009
Hull
Is there anyway of fixing a slight leak on an mdpe compression plastic fitting in a similar way to when you wrap ptfe around an olive on copper compression fittings. I guess there's isn't as its an oring seal. Thanks.
14 Sep 2010
Rochdale
Is it a Plasson or Philmac?
Plasson are really push fit and the nut stops the water pressure pushing the pipe out. They can show a slight leak if the pipe is scratched or scuffed.
Philmacs are a compression fitting and would seal on a scratched of scuffed pipe once tightened.
14 Sep 2010
Rochdale
If you can see the scratch you can usually rub it off with a Stanley blade.
If you can’t do that you would have to cut back to clean pipe or swap it out for a Philmac.
