small cheep electric shower wanted
Yes it does. A dedicated radial circuit is required ,as would any instantaneous electric shower.
It would need to be on a separate 40 amp circuit breaker with the correct size cable to withstand the current.
can I get something that would run off of a 13amp circuit?
Is this so you can unplug it and take it with you if you move house? A shower needs it’s own circuit and certainly not 13Amp.
With a 1.2m cord to plug into ones extension lead as there won't be a wall socket close enough. Wrapping the extension lead in a plastic bag is an optional safety recommendation.
Nozzle
In gods name were are some people's brains this is the same mentality which keeps cowboys in work
and the fire brigade and ambulance service busy. Bob
A 13amp circuit is only capable of running a 2kw appliance. That's why most electric fires are only rated upto 2kw, to make them more or less plug & play with a 3 pin plug. Same with a kettle. If you want an electric shower, you are going to have to bite the bullet and dip your hand in your pocket to have one installed correctly.
