Hi there. can i run something by you
I'm considering smoke alarms. Just wanted to check something out. At the electrical shop today the bloke behind the counter states that you have to come out of the consumer unit with 1mm T & E to the first smoke detector and then from the first one to the second smoke detector and all subsequent smoke detectors you should use 1mm 3 Core and Earth. Does this sound right. I take it that a 6 MCB way in the consumer is right.
Thanks in adavnce
Thanks in adavnce
