To mount my wall outlet I i need to use the 1/2" ear elbow which from what I can see is what most of the 1/2" fixings seem to thread into. I've come across the following at ToolStation. Is this fitting a solder connection on the 15mm inlet?
www.toolstation.com
One issue I see is that the fitting may actually be a bit too far back rather than it sitting flush at the finished tiled level. Are there any alternatives to this? or are you supposed to use some sort of extension to it? Preferably I want the inlet bit to be solder connection.
Made4Trade End Feed Wall Plate Elbow
End feed capillary fitting is part of the Made4trade range and manufactured to BS EN 1254-4. This fitting joints copper tube manufactured to BS EN 1057 using solder.It is suitable for above ground hot and cold domestic or potable water services, central heating systems, low-pressure steam...
