Solid fuel fire flue
8 Nov 2005
Caithness
I am replacing a gas fire with a solid fuel fire in the fireplace. Can anyone tell me how I fit the new flue to the excisting chimney. I am hoping that it is just place the flue up the chimney and seal it.
Any help please.
Steve
Hi, I think you need a large firebrick insert (in two parts usually) which has a smoke shelf. this fill the whole opening and is ready to take a basket and side bricks (slim fire brick inserts). You then check the 9 inch square flue for lining condition- and away you go!- Any help?
The two parts are to allow for expansion.
Solid fuel fire or solid fuel stove? What age is your house, what is it built of?
The house is built of brick a 100 years old. Want ot use Solid Fuel. Will know more when I get in.
Many Thanks to all
Bylough , any chance you could post pics or links to the item you are talking about , i have a solid fire that has been unused for ages and was wondering what i needed to get it started but i'm starting to get a little confused with all the terms , firebreak , firebricks , firebaskets , smokeshelfs etc
will try and post a pic next week of my fireplace and try and explain my situation a bit better
TIA
Derek
Hi Woo-- , I am not an expert on open fires. I have some pics- but I'm not into 'posting' them yet.
My new fireplace and flue at ground floor is a precast affair, gotten from our builders merchant- with some advice to go with it- and I worked the rest out myself. These flue sections are 9 inch bore (square) and fit into each other with a flange, duly 'glued' with fire cement (black). They look like breeze blocks. The fire opening back and sides (two piece with division half way up for expansion- ie split) This part is a nice looking brown firebrick colour. A top part- the lintol- is also the smoke shelf ( to prevent downdraft). You should arrange the flue to be vertical a fair bit before any bends if these are required. I assembled all this as I build up the brick chimney breast ( on a good concrete base and keyed-in bricks).
Hope this helps a bit.
ps- I also found an old householder book with building a fireplace artical in it.
The difference is what type of fire you want to fit.
If you want a solid fuel stove then you don't need to rebuild the fireback.
I had an inglenook fireplace in my old house, so I could just fit the whole stove in the fireplace.
The bottom of the fireplace opening was just quary tiled. As the stove was quite high off the ground it wouldn't get too hot.
I then just took a stainless steel linner straight up the chimney.
Hazelb- that sounds better than my long winded trollop!
Of course- in my case I had to start with no chimnet breast.
Thanks for all your comments and advise. I am looking forward to getting in the house and starting this project.
Steve
