Solution needed
Discussion in 'General DIY' started by dantheram, 18 Jul 2014.
  1. dantheram
    dantheram
    26 Oct 2012
    129
    Thanks Received:
    Derbyshire
    Country:
    i am fitting an end cap to a worktop but there is a slight complication, the worktop runs slightly long than the wall it butts onto, see below -
    [​IMG]
    should i cut it down, leaving a lip, and bend the lip round the back of the worktop edge?
    also, is it best to hacksaw it down to size?
    Many thanks,
    Dan
  2. Sponsored Links
  3. foxhole
    foxhole
    14 Mar 2006
    18,205
    Thanks Received:
    2,089
    Kent
    Country:
    The worktop needs cutting back as close as is safe and then apply the end cap, or you risk catching your hip/leg on the corner [and it will look pants.]The edging strip supplied with the top would look neater and allow a closer finish.
  4. dantheram
    dantheram
    26 Oct 2012
    129
    Thanks Received:
    Derbyshire
    Country:
    trouble is i can't get my handheld circular saw all the way along the cut because the wall gets in the way - would it make a crap cut if i finished it with a hand saw?
  5. foxhole
    foxhole
    14 Mar 2006
    18,205
    Thanks Received:
    2,089
    Kent
    Country:
    YOU DON'T CUT IN SITU , take off top to cut down.
  6. dantheram
    dantheram
    26 Oct 2012
    129
    Thanks Received:
    Derbyshire
    Country:
    i can't, i remodelled that area of the kitchen and the worktop has remained in situ. taking it off would mean taking the sink out and countless other tasks.
  7. flameport
    flameport
    10 Mar 2007
    10,086
    Thanks Received:
    2,035
    Poole, Dorset
    Country:
    Yes, it will look hideous. The cut will be uneven, the laminate will chip, it will be a dogs dinner.
    The proper method is to remove the worktop (or at least slide it away from the wall and unit below), then trim the end to the proper length using a router, and fit a suitable edging strip to the end.
    Anything else will be a horrible bodge and look like it.
  8. gregers
    gregers
    28 Mar 2008
    6,301
    Thanks Received:
    500
    Sussex
    Country:
    this is where you need a cack handed chippy,cut it down using a hand saw.
    then cheat a little with some filler and build the wall out a tad to lose the thickness of the laminate end cap.
  9. Sponsored Links
  10. dantheram
    dantheram
    26 Oct 2012
    129
    Thanks Received:
    Derbyshire
    Country:
    so annoying i've spent ages doing the kitchen and now i've got this tiny bit left and it's being a sod to get right!
  11. foxhole
    foxhole
    14 Mar 2006
    18,205
    Thanks Received:
    2,089
    Kent
    Country:
    You could take the end down with a power plane which will leave a good edge and a belt sander would allow you to get very close to the edge of the unit.
  12. dantheram
    dantheram
    26 Oct 2012
    129
    Thanks Received:
    Derbyshire
    Country:
    Thanks for the idea! I'm not trying to have it fit for a king, just a reasonable finish will suffice. Hopefull your solution will give this 😊
  13. phatboy
    phatboy
    22 Jan 2012
    2,197
    Thanks Received:
    259
    Jersey
    Country:
    Exactly this! An electric planer will do the trick. PLANE FRONT TO BACK!! Otherwise you will rip the laminate at the front.
    Set the machine to maximum depth until you are practically done, then go down to a very small bit to take off any minor chips. Then you can glue on the edging strip that came with the worktop, using evostick, a layer on the strip and one on the worktop.
  14. mattylad
    mattylad
    27 Apr 2008
    8,415
    Thanks Received:
    646
    Country:
    And cover EVERYTHING with plastic sheeting (poundland do it for - yes a pound) as it will get covered in sawdust.
  15. Or, just don't bash into it.
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
