Rockwool Flexi (which is a slab) is more dense than ordinary mineral wools and is designed for its superior sound attenuation. Thermal insulation wools are lighter.
Thanks for your replys. The reason i ask is because i am putting a en-suite toilet in a bedroom and the building inspector wants insulation in the wall adjoining the next bedroom. Was going to put two layers of 50mm slab and then two layers of soundbloc plasterboard.
