Spec of pipe to gas fire
26 Apr 2011
Dunbarton
Looking for a little advice. Are there any regs (scotland) regarding the type of pipe, ie pvc coated or not to be run under the floor to supply a gas fire? First floor so no issues with damp/cold. I'm guessing best practice is to go with pvc coated but need to understand if non costed copper is acceptable. Many thanks
Long story which I'll not go into here. Suffice to say we need to understand what type or pipe should be used. Thanks
If it is just a normal timber floor then non coated is ok.
If you dont explain your situation then we think that there is likely to be some illegal DIY work proposed.
Tony
Aye, fess up!! You're really from the Drum & doing it as a homer for some drug dealer!! I'm calling the Polis!!
Ah, you've jumped to the wrong conclusion. As I say what is needed is clarity as to what should be in situ based on current standards, I am guessing a gas safe engineer should be able to help.
It doesn't have to be coated under floor but should be inside builders opening.
You have already been told the answer by at least 3 RGI's. Also the important note about the pipe in the BO
