Hi all,
I have a new granny annexe which I have run 16mm 2 core SWG to and has it's own consumer fuse box and earth.
I was wondering how I should wire this up to the main property (feed), I wish to fuse the 16amp spur safely but as high as possible, what fuse size would be appropriate 60amp/80amp and how should this be set up correctly, (obviously can't be connected into the existing fuse box because of the fuse rating).
I have a 100amp fuse in the main property and thought that I could split the original tails in a henley block with maybe a 100amp double pole isolator along with a suitable fuse, if this would be the correct procedure could anyone recommend the parts that I would require.
Any help on the correct procedure would be greatly appreciated.
Many thanks, Martin
Many thanks, Martin
