Split tails using t+e and heat shrink with photo
24 Oct 2009
Hampshire
View media item 50265This is in a top floor flat, they had Wicks into fit the Kitchen and the electrician fitted a dedicated CU for the new work, lets play spot the codes.
Oh he did not register the job despite at the time being a member of NICIEC and on the EIC he left a blank space where is says Supply Conductor CSA[/img]
That 6milli feeding the "CU"?
That is no moe than an enclosure with mismatched accessories in it...
IP breaches, that tape on the fuse carrier is awful, no cover for the Wylex unit. Single insulation looks like it's visible.
Urgghhhh!
Should be put against a wall and shot.
Yes the customer called the NICIEC and have started their complaints procedure - they are sending a form. Also Wickes; when we called them, were not at all surprised and said that they have had a lot of complaints about this guys work, which begs the question WTF did they not contact ALL of the people he has done work for on their behalf and send out an electrical inspector to check that no one was going to burn down and that all of the jobs have been registered with the BCO. I am planning to attend site when Mr Wickes comes to take a look. The customers are couple who are very savy and I don't think that they will let this rest. The property is currently being sold and the other sides solicitor wants a completion certificate on the kitchen..........
I have been called back today to examine the remedial works and to put an EICR that says satisfactory on it. I have a little trouble doing it.
The "new" electrician when ask for a certificate for his work, told the customer that my EICR would cover his remedial work
Does any one want to see a photo of the above instal after his remedial work? :D
no. because it may trump mine. my customer had wickes out and the electrician split the tails from a henly block with 10mm twin and earth and into a switch fuse rated at 80A. the incoming supply was a 60 Amp and the sheath was removed 100mm as it entered the henly and switch fuse. when i find photo, will post
