Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Can anyone tell me how many downlighters can I have running from one pull switch in the bathroom . They will have 40w Gu10 bulbs. And can they be run off normal lighting cable.
Your pull cord switch will be rated at about 10A.
So (10x230)/40.
But you will be restricted by the current rating of the existing circuit and the the rest of the load on that circuit.
The circuit can be normal lighting cable if you mean 1.00mm or 1.5mm twin and earth.
You may have issues with the final connection at the fittings, due to heat dissipation from the lamp and heat resistant cable/flex may be required.
This will depend on how the jointing box of the fitting is positioned.
That will depend on what the council says about Part L (from the POV of lighting efficiency) when you apply for permission to install them.
Don't forget you may well also have to address compliance with some or all of Part B, Part C, Part E, Part L (regarding thermal insulation) and Part P.
