Steel drills question
26 Sep 2011
Would someone kindly tell me where to get a drill for drilling a piece of metal and what to ask for.
I know this sounds simple but I don't know one drill bit from another (except masonry bits I know what they look like .
hss high speed steel
if its say a 10mm hole drill a 6mm hole first
Could you post a pic so I can see what it looks like, or give me a link to an amazon site or similar
How thick is your metal, if you are drilling through thin sheet a piece of wood on the back side will help, if its thick stuff you will need to keep the drill bit cool.
Make sure the metal is held firm, & let the drill do the work.
the dewalt hss bits are self starting so you dont really need to drill a pilot hole first, remember to go as slow as you can, heat up the bit and it will be USELESS
The pic shown by Dave seems to be the same as I've got but it doesn't seem to do anything.
Drill is 6.5mm what I'm drilling is an inch thick garden gate which may or may not be solid, I was hoping it would be hollow
Sounds like the drill is blunt. A new one should put a 6.5 mm hole through 25mm MS without too much effort. Either sharpen the drill, which needs either a drill sharpener or a grinder and the right technique, or get a new decent quality HSS drill.
A 6.5 mm drill through 1" steel would be ok so long as you are using a pillar drill where you can apply lots of pressure and the speed is low.
If you are using a hand pistol drill (mains) keep the speed low, use a smaller drill first and use plenty of lubrication (WD40, Duck oil will be fine).
Multi use High Speed Drills are often referred to as 'jobber' drills.
John :)
HSS will run very hot while still cutting and holding an edge.
Some of the HSS alloys will still cut when "red hot".
So while it doesn't hurt anything to lubricate the cut it's not strictly necessary unless you are looking for a very fast cut. I used to regularly drill 1/4" holes in steelwork up to about 1/2" using a hand held drill, low speed and not too much pressure. Having a sharp bit is the secret. 1" will just take a bit longer, and a bit more care to keep the drill straight.
If your drill has a clutch, don't forget to set the torque.
As the bit starts to pop out of the other side it grabs and you could easily break your wrist if not careful.
Some of the cheaper ones aren't worth a monkeys.
Wouldn't drill thru butter.
Dormer, as highlighted in a previous post is one of the better makes.
All steel drilling should have coolant applied. If heating is involved then the edge life is shortened dramatically and the tempering is affected further reducing the effectiveness of the bit.
Especially after re-sharpening.
You mean "cut" them selves to pieces.
