Steel over walls
22 Mar 2006
Yorkshire
Hi all
Need help thanks in advance.
Recent visit by building inspector gave me an idea. He suggested I build two columns to accomodate a steel beam(s) giving me a bit more room which I would have lost in building a partition wall.
Concrete in foundations poured tomorrow. What is the best method of building columns to support steel and a load bearing wall. Span 3800. Wall with cavity of 100 above beams. Wall height 2500.
a structural engineer should advise as this is a very specific and important element.
are the columns freestanding or tie into existing masonry?
regardless, i would say lightweight blockwork is a no-no.
do you mean you have a twin skin wall with 100mm cavity above?
I would suggest building the piers from engineering brick, size of piers will depend on location and load
