stopcock help upper cottag flat (4 in a block)
16 Jun 2012
Lanarkshire
Am having a nightmare - my flatmate accidentally knowcked the bathroom sink off the wall so we're planning on replacing it this weekend and thought we'd replace the bathtaps etc at the same time but we cannot find the stopcock for the hot water.
anyone know where this would be for an upper 4 in a block?
thanks,
Once you turn the cold main off then it will turn the hot off at the same time
If you look under the boiler there should be an isolating tap for the boiler , if you turn this off it will isolate the hot water,
what combi do you have ?
