I fitted a strapon to a 110mm soil pipe. The strapon had an insert of roughly 53mm and i drilled a hole of 51mm and filed the rest. I assumed that the insert of the strapon had to fit snugly into the hole i drilled in the soil pipe. I then fitted the strap on with solvent cement and tightened it. I have a leak.
I think i fitted the strapon wrong. On reflection i think I should have drilled a 40mm hole and the 53mm insert would have covered the 40mm hole.
The waste pipe to the soil pipe is 40mm.
Can anyone give me advice on how to properly onnect a strap on,
thanks in advance
scott
thanks in advance
scott
