I'm about to fit a new plastic bath (standard size/shape) but the instructions for fitting the legs are a bit vague regarding the placing of these.
Each leg set consists of threaded rods + adjusting nut(s) that locate into a piece of steel angle which has to be attached to the reinforced section of the bath base with wood screws.
Is there an optimum position for these or should they just be fitted a couple of inches in from each end of the reinforced section ?
Dave.
Dave.
