    Dismiss Notice
Sub floor advice needed
Discussion in 'Floors, Stairs and Lofts' started by lmsava, 27 Mar 2007.
  1. lmsava
    lmsava
    15 Aug 2006
    66
    Thanks Received:
    Country:
    I'm going to lay vinyl floor tiles in my bathroom and I'm unsure about the type of sub-floor I'll need to put down. I was going to use 16mm ply as this seems to be a bit easier than hardboard. Is this OK or is it too thick?
    Also, I'm planning to seal it with PVA. Can ayone tell me the ratio at which I should mix the PVA and how many coats it will need, I think it's 1 part PVA to 4 parts water but I'm not sure.
    Cheers.
  2. gcol
    gcol
    22 Sep 2005
    6,593
    Thanks Received:
    68
    Preston, Lancashire
    Country:
    Is there any flooring down at present? If not, screw down 18 or 25mm WBP ply to the joists (with extra support under the joints). If floorboards are fitted, you should be ok with 6mm ply over the top.
    Regarding sealing - are the tiles self adhesive? If not, what do the instructions say on the adhesive you plan to use? I would have thought that they wouldn't have mentioned PVAing the ply at all.
  3. Sponsored Links
  4. lmsava
    lmsava
    15 Aug 2006
    66
    Thanks Received:
    Country:
    We've got floorboards down at the minute.
    The tiles are self-adhesive. The instructions say to make sure that plywood is sealed with a suitable primer but it doesn't give any examples. Any ideas of what I should use?
  5. gcol
    gcol
    22 Sep 2005
    6,593
    Thanks Received:
    68
    Preston, Lancashire
    Country:
    I'd be inclined to phone their technical department and ask them what they recommend.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
