SUNVIC white box is making a noise
Discussion in 'Plumbing and Central Heating' started by Techboy, 17 May 2020.
Tags:
  1. Techboy
    Techboy
    14 Sep 2005
    39
    Thanks Received:
    Buckinghamshire
    Country:
    The plate the head unit sits on is very rusty. I cleaned it up and can't feel any moisture anywhere.
    [​IMG]
    [​IMG]
  2. oldbuffer
    oldbuffer
    6 May 2010
    1,500
    Thanks Received:
    564
    London
    Country:
    If its unvented:
    1. I wouldn't replace with a motor on - motor off valve, they are not fail safe.
    2. You shouldn't be working on it as you need a G3 qualification to do anything which affects the safety features, and that valve does.
  3. Sponsored Links
  4. Techboy
    Techboy
    14 Sep 2005
    39
    Thanks Received:
    Buckinghamshire
    Country:
    Ah okay. What should I replace it with? :)
  5. Techboy
    Techboy
    14 Sep 2005
    39
    Thanks Received:
    Buckinghamshire
    Country:
    It turns out that the issue was with the brass valve that the Sunvic controls! I lifted up the Sunvic, quirted the valve with WD40, used pliers to turn it until it was free to move, put the Sunvic back on and now the Sunvic is quiet and is able to operate the value as it should.
    Thanks everyone for the help :)
    • Like Like x 1
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
