supply two 5 amp kitchen appliances from one FCU
4 Jan 2007
London
chaps,
Is it ok to feed two 5 amp kitchen appliances from one fused FCU. I was hoping to supply a feed to the lights under the fitted kitchen wall units and also the gas hob ignition .
Cheers
Moe
As long as it's switched (requirement for isolation methinks), shouldn't be a problem if labelled correctly, as the fuse is there to protect the flex - unless it's that stupid 3 amp flex on the lights.... all notifiable though...
