Suprima 30L no hot water
10 Mar 2005
we had to replace the gaskets on the main pump (circulating Pumps - CP53) as the people that installed it must of done it badly.
Since then the CH is ok, but i cannot get any hot water, the boiler does not seem to want to fire up (pressed the rest button)
Got a 2 week old baby and i am desperate
what is that meant to mean?
we get flooded while we wait for superman or what?
done that, only tells me about health and safety, are you trying to tell me to get a plumber?
thanks, did you place another link? as there is nothing there.
Boiler - Suprima 30L - Gas / Santon Premier Plus
No Hot Water
Had to remove CP53 pump because of bad leak, replaced gasket and refitted.
Pump refitted yesterday at 16:30, problem started yesterday 22:00
thanks
the silver one on the brass pipes is motorised and seems to be working....i am having trouble locating the 3 way valve.....could it be located on the top or the bottom of the cp53 valve?
there are 2 that we think it may be....
the first one having 3 pipes but it does not look like valve....it is at the highest level and looks like a top hat.
the secomd being a white box but only has 2 pipes that we can see or feel which is at the bottom of the sp53 valve.
the is a cold water combination valve that has 3 pipes to it but my guess is that aint it.
Cheers for your patience.
