suspended ceiling
10 Apr 2004
i'm thinking of lowering my ceiling in my kitchen which is about 4m *3m by fitting a suspended ceiling using a light weight tongue and groove and fitting four downlighters in it.
my question is ,what is the best way to fit the framework to fix the t & g to,i was thinking of 3x2 roughsawn timber fixed with screws around the perimeter of the walls and additional beams of 3x2 across the room at 18 inch intervals.will this be o.k. or would some support from the cross beams to the ceiling be advisable? i am lowering the ceiling by about 1ft.
any advice would be much appreciated.
You are right with your method but instead of fixing the wall plates with screws I would advise using Rawlbolts, something like M8 X 120mm and then fixing 2" wide timber to timber joist hangers to carry the ceiling studs. Fix the wall plates along the 4 metre lengths so your ceiling joists are 3 metres long and with the 18" centres you won't need any additional support from above.
